Ir para o conteúdo principal
Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Casio Exilim EX-Z850 Flash Assembly Replacement
O que você precisa
  1. Casio Exilim EX-Z850 Flash Assembly Replacement, Flash Assembly: passo 1, imagem 1 %32
    • Remove the four screws on the side of the speaker.
  2. Casio Exilim EX-Z850 Flash Assembly Replacement: passo 2, imagem 1 %32
    • Remove the two back screws on the bottom of the camera.
    • Note: Bottom screws are longer than the top ones, so label accordingly for easy reassembly.
  3. Casio Exilim EX-Z850 Flash Assembly Replacement: passo 3, imagem 1 %32
    • Remove the four screws on the side opposite of the speaker.
  4. Casio Exilim EX-Z850 Flash Assembly Replacement: passo 4, imagem 1 %32 Casio Exilim EX-Z850 Flash Assembly Replacement: passo 4, imagem 2 %32
    • Once all screws have been removed, gently pry open bottom casing.
    • With tweezers, carefully remove ribbon from LCD screen.
    • Set bottom casing aside.
  5. Casio Exilim EX-Z850 Flash Assembly Replacement: passo 5, imagem 1 %32 Casio Exilim EX-Z850 Flash Assembly Replacement: passo 5, imagem 2 %32 Casio Exilim EX-Z850 Flash Assembly Replacement: passo 5, imagem 3 %32
    • Gently pry apart the top casing using tweezers.
    • Set the top casing aside.
  6. Casio Exilim EX-Z850 Flash Assembly Replacement: passo 6, imagem 1 %32 Casio Exilim EX-Z850 Flash Assembly Replacement: passo 6, imagem 2 %32
    • Use tweezers or prongs to pry the LCD screen off from the opening.
    • Note: The bottom of the LCD screen is attached to the frame by a few pieces of black tape.
  7. Casio Exilim EX-Z850 Flash Assembly Replacement: passo 7, imagem 1 %32 Casio Exilim EX-Z850 Flash Assembly Replacement: passo 7, imagem 2 %32
    • Lift up the LCD screen, slowly move it to the other side.
  8. Casio Exilim EX-Z850 Flash Assembly Replacement: passo 8, imagem 1 %32 Casio Exilim EX-Z850 Flash Assembly Replacement: passo 8, imagem 2 %32
    • Pry off the LCD casing.
  9. Casio Exilim EX-Z850 Flash Assembly Replacement: passo 9, imagem 1 %32 Casio Exilim EX-Z850 Flash Assembly Replacement: passo 9, imagem 2 %32 Casio Exilim EX-Z850 Flash Assembly Replacement: passo 9, imagem 3 %32
    • Flip open the connector holding the ribbon.
    • Pull out the LCD screen with the ribbon from the camera.
  10. Casio Exilim EX-Z850 Flash Assembly Replacement: passo 10, imagem 1 %32 Casio Exilim EX-Z850 Flash Assembly Replacement: passo 10, imagem 2 %32
    • Remove two screws on the side where the battery is located.
    • Remove the lanyard loop after the screws come off.
    • Slowly pull the side casing so it becomes dislocated from the top of the camera frame.
  11. Casio Exilim EX-Z850 Flash Assembly Replacement: passo 11, imagem 1 %32 Casio Exilim EX-Z850 Flash Assembly Replacement: passo 11, imagem 2 %32
    • On the front of the camera near the flash flip the connector holding the ribbon.
    • Remove the ribbon from the connector.
  12. Casio Exilim EX-Z850 Flash Assembly Replacement: passo 12, imagem 1 %32 Casio Exilim EX-Z850 Flash Assembly Replacement: passo 12, imagem 2 %32 Casio Exilim EX-Z850 Flash Assembly Replacement: passo 12, imagem 3 %32
    • Carefully remove the L shaped frame from the camera.
    • At the bottom of the camera the L shaped frame is being held in by two plastic bumps and a metal tab.
    • Pop the frame off the bumps and tabs.
    • Note: There is a yellow and orange wire soldered onto the camera. Be careful not to pull them off.
  13. Casio Exilim EX-Z850 Flash Assembly Replacement: passo 13, imagem 1 %32 Casio Exilim EX-Z850 Flash Assembly Replacement: passo 13, imagem 2 %32
    • This is the flash assembly.
    • It needs to be removed with soldering points circled.
Conclusão
Uma outra pessoa concluiu este guia.
Christian
Membro desde: 01/28/11
320 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 4-38, Regan Winter 2011 Membro de Cal Poly, Team 4-38, Regan Winter 2011
CPSU-REGAN-W11S4G38
Membros da 4
Autoria de 13 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 14
Duração total: 2,791
