Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
If you would like to clean your camera or check the connections, this guide describes how to remove the battery casing on the camera.
O que você precisa
Pull the L-shaped frame away from the camera without disconnecting any of the wires.
At the bottom of the camera, the L-shaped frame is being held in place by two studs and metal tabs.
Pop the frame off of the studs and metal tabs.
There is a yellow wire and an orange wire soldered to the camera. Do not disconnect them.
