Ir para o conteúdo principal
Casio Exilim EX-Z70 Memory Card Replacement
  1. Casio Exilim EX-Z70 Memory Card Replacement, Memory Card: passo 1, imagem 1 %32 Casio Exilim EX-Z70 Memory Card Replacement, Memory Card: passo 1, imagem 2 %32 Casio Exilim EX-Z70 Memory Card Replacement, Memory Card: passo 1, imagem 3 %32
    • Orient the camera with the lens facing to the right and the bottom of the camera toward you.
    • Grasping the camera tightly, press downward firmly on the piece with the label and slide it towards the LCD screen (to the left).
    • The flap will then swing upward.
  2. Casio Exilim EX-Z70 Memory Card Replacement: passo 2, imagem 1 %32 Casio Exilim EX-Z70 Memory Card Replacement: passo 2, imagem 2 %32
    • Push down on the memory card (located behind the battery) and then release pressure completely.
    • The memory card will automatically rise part way out of its compartment.
    • Grasp the memory card on each side and simply slide it out of its compartment to remove it.
  3. Casio Exilim EX-Z70 Memory Card Replacement: passo 3, imagem 1 %32 Casio Exilim EX-Z70 Memory Card Replacement: passo 3, imagem 2 %32 Casio Exilim EX-Z70 Memory Card Replacement: passo 3, imagem 3 %32
    • If your memory card is locked, there is a metal slider on the left side that can be moved up to unlock the memory card.
Conclusão
Paul Fallon
Membro desde: 04/10/12
141 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team 17-28, Amido Spring 2012 Membro de Cal Poly, Team 17-28, Amido Spring 2012
CPSU-AMIDO-S12S17G28
Membros da 4
Autoria de 14 guias
2 comentários
My Casio camera works great until I insert the memory card. When it doesn't have the memory card, it turns on, the lenses come out and everything but as soon as I insert the memory card, the lenses will come out have way, and then the camera shuts off like that. The only way to get the lenses to get inside and the camera to turn on, is to remove the memory card. HELP ME PLEASE!
Miriam - Responder
I have a similar issue. My camera won’t recognize the SD card! It’ll turn on & take pic’s in the Memory area, but them it’s FULL after a few. Isn’t there something that can be done?
I see NO ONE HAS ANSWERED THE LAST PERSONS QUESTION….????????????
Lynn Lehr - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 14
Últimos 30 dias: 43
Duração total: 3,360
