Peças
Não são necessárias peças.
    • Open the battery door by sliding it toward the LCD screen.
    • This will reveal a small screw to the left of the memory card slot.
    • Carefully remove the screw (1.77mm).
    • The bottom panel of the camera will become loose. It is connected to the camera by two wires so do not remove completely.
    Adicionar comentário
  1. We have oriented the camera with the lens up and the flash toward you for clear visibility.
    • We have oriented the camera with the lens up and the flash toward you for clear visibility.
    • Use a pair of tweezers to gently move the red and black wires away from the lens.
    • Using tweezers or finger nails to pull up the brown flaps where the three orange film strips meets the circuit board.
    • Use tweezers to pull the orange film strips out of each port. Be sure to do this to all three orange strips. They should come out easily.
    • Pull the circuit board away from the camera.
    • Be careful the circuit board is still attached to the camera by a black film strip.
    • Gently pull off the plastic cover over the LCD screen
    • Gently pull the LCD screen away from the camera. Be careful since the screen is still attached to the camera circuit board.
    • You have now completed the guide to remove the the LCD screen.
Conclusão
Jenn Eberts
221 reputação
2 Guides authored
Equipe
Cal Poly, Team 17-28, Amido Spring 2012 Membro de Cal Poly, Team 17-28, Amido Spring 2012
CPSU-AMIDO-S12S17G28
4 Membros
9 Guides authored
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Todo: 304
