Ir para o conteúdo principal
Casio DW-6900 Watchband Replacement
O que você precisa
  1. Casio DW-6900 Watchband  Replacement, Watchband: passo 1, imagem 1 %32 Casio DW-6900 Watchband  Replacement, Watchband: passo 1, imagem 2 %32 Casio DW-6900 Watchband  Replacement, Watchband: passo 1, imagem 3 %32
    • There are four screws— two on each side of the watch case.
    • Use the Philllips screwdriver to remove four 4.5 mm screws.
  2. Casio DW-6900 Watchband  Replacement: passo 2, imagem 1 %32 Casio DW-6900 Watchband  Replacement: passo 2, imagem 2 %32
    • There are two trunnions on both sides of the watch, and there are four grooves.
    • Use a small flat-blade screwdriver and push inward to remove the trunnion. And remove the strap.
  3. Casio DW-6900 Watchband  Replacement: passo 3, imagem 1 %32
    • From the bottom of the watch, buckle the case from the main body of the watch by hand.
  4. Casio DW-6900 Watchband  Replacement: passo 4, imagem 1 %32
    • Align the hole on the side of the case with the button on the watch and put on the new watch case.
  5. Casio DW-6900 Watchband  Replacement: passo 5, imagem 1 %32 Casio DW-6900 Watchband  Replacement: passo 5, imagem 2 %32 Casio DW-6900 Watchband  Replacement: passo 5, imagem 3 %32
    • Thread the trunnion into the small hole on the strap.
    • First, snap one side of the trunnion into the hole of the watch body.
    • Use a flat-blade screwdriver to push the other end of the trunnion into the main body of the watch.
  6. Casio DW-6900 Watchband  Replacement: passo 6, imagem 1 %32 Casio DW-6900 Watchband  Replacement: passo 6, imagem 2 %32
    • Screw on the four screws on both sides of the watch.
Conclusão
Shaoguang He
Membro desde: 05/10/21
133 Reputação
Autoria de 1 guia
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 17
Últimos 30 dias: 72
Ao todo: 3,260
