Ir para o conteúdo principal
Casio Cassiopeia E-125 Touch Screen Replacement
O que você precisa
  1. Casio Cassiopeia E-125 Touch Screen Replacement, Battery: passo 1, imagem 1 %32
    • Flip the device over to the back side.
  2. Casio Cassiopeia E-125 Touch Screen Replacement: passo 2, imagem 1 %32
    • Slide the small switch on the back to "MAIN".
  3. Casio Cassiopeia E-125 Touch Screen Replacement: passo 3, imagem 1 %32
    • Slide the battery cover downwards.
    • Pull off the battery cover.
  4. Casio Cassiopeia E-125 Touch Screen Replacement: passo 4, imagem 1 %32
    • Pull the black tab to remove the battery.
  5. Casio Cassiopeia E-125 Touch Screen Replacement, Touch Screen: passo 5, imagem 1 %32
    • Use the Phillips #00 screwdriver to remove the two screws near the top of the device.
  6. Casio Cassiopeia E-125 Touch Screen Replacement: passo 6, imagem 1 %32
    • Use the Phillips #00 screwdriver to remove the two screws located inside the battery compartment.
  7. Casio Cassiopeia E-125 Touch Screen Replacement: passo 7, imagem 1 %32
    • Use a spudger or opening tool to separate the two halves of the case.
  8. Casio Cassiopeia E-125 Touch Screen Replacement: passo 8, imagem 1 %32
    • Pry the two halves of the case apart with the opening tool.
  9. Casio Cassiopeia E-125 Touch Screen Replacement: passo 9, imagem 1 %32
    • Potential for device damage. Do not pull apart the wires connecting the outer case.
    • Lay the two halves of the outer case next to the central components as shown.
  10. Casio Cassiopeia E-125 Touch Screen Replacement: passo 10, imagem 1 %32
    • Use the Philips #00 screwdriver to remove the three screws in the corners of the screen.
  11. Casio Cassiopeia E-125 Touch Screen Replacement: passo 11, imagem 1 %32 Casio Cassiopeia E-125 Touch Screen Replacement: passo 11, imagem 2 %32
    • Lift the tab on the motherboard and pull out the ribbon cable.
    • After the ribbon cable is detached from the motherboard, the touch screen is completely separated from the device.
Conclusão
Ryan Fernandez
Membro desde: 04/03/12
47 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team 5-4, Forte Spring 2012 Membro de Cal Poly, Team 5-4, Forte Spring 2012
CPSU-FORTE-S12S5G4
Membros da 6
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 12
Duração total: 991
