Ir para o conteúdo principal
Casio CZ-1000 Piano Key Replacement
O que você precisa
  1. Casio CZ-1000 Piano Key Replacement, Backplate: passo 1, imagem 1 %32 Casio CZ-1000 Piano Key Replacement, Backplate: passo 1, imagem 2 %32
    • Use a Phillips #1 screwdriver to remove the eleven 7.5 mm screws securing the back plate.
  2. Casio CZ-1000 Piano Key Replacement: passo 2, imagem 1 %32 Casio CZ-1000 Piano Key Replacement: passo 2, imagem 2 %32 Casio CZ-1000 Piano Key Replacement: passo 2, imagem 3 %32
    • Using a Phillips #1 screwdriver, remove all 14 5.5 mm screws from the two motherboards.
    • These screws secure the motherboards to the keyboard assembly and the dial on the right side.
  3. Casio CZ-1000 Piano Key Replacement: passo 3, imagem 1 %32 Casio CZ-1000 Piano Key Replacement: passo 3, imagem 2 %32 Casio CZ-1000 Piano Key Replacement: passo 3, imagem 3 %32
    • Carefully cut the zip tie located in the right-hand corner using a pair of scissors or wire cutters.
    • Be sure to avoid cutting any nearby wires or components.
    • Gently slide all the plugs out of their sockets.
    • This will prevent them from catching on anything or damaging the connectors as you lift.
  4. Casio CZ-1000 Piano Key Replacement, Piano Key: passo 4, imagem 1 %32 Casio CZ-1000 Piano Key Replacement, Piano Key: passo 4, imagem 2 %32
    • Remove the four 7.5 mm screws using a Phillips #1 screwdriver.
    • Lift the rectangular circuit board away to expose the underside of the key bed.
  5. Casio CZ-1000 Piano Key Replacement: passo 5, imagem 1 %32 Casio CZ-1000 Piano Key Replacement: passo 5, imagem 2 %32
    • Remove the six 7.5 mm screws using a Phillips #1 screwdriver.
  6. Casio CZ-1000 Piano Key Replacement: passo 6, imagem 1 %32 Casio CZ-1000 Piano Key Replacement: passo 6, imagem 2 %32
    • Grab the key bed by the side shown.
    • Lift the key bed up and slide it out from the black case.
  7. Casio CZ-1000 Piano Key Replacement: passo 7, imagem 1 %32 Casio CZ-1000 Piano Key Replacement: passo 7, imagem 2 %32
    • Flip the key bed over so that the keys are facing up.
    • Using a pair of tweezers, detach the spring from both the metal bar and the key itself.
    • Lift the key out of the slot in the metal bar and replace!
Conclusão
CJ Fagundo
Membro desde: 10/31/24
159 Reputação
Autoria de 1 guia
Equipe
Cuesta, Team 60-3, Krynen Fall 2024 Membro de Cuesta, Team 60-3, Krynen Fall 2024
CUESTA-KRYNEN-F24S60G3
Membros da 4
Autoria de 5 guias
Um comentário
Disassembly went fine, but my cz1000 keys don't look the same
Brian Marshall - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 27
Duração total: 62
