Ir para o conteúdo principal
Casio CZ-1000 Display Screen Replacement
O que você precisa
  1. Casio CZ-1000 Display Screen Replacement, Backplate: passo 1, imagem 1 %32 Casio CZ-1000 Display Screen Replacement, Backplate: passo 1, imagem 2 %32
    • Use a Phillips #1 screwdriver to remove the eleven 7.5 mm screws securing the back plate.
  2. Casio CZ-1000 Display Screen Replacement: passo 2, imagem 1 %32 Casio CZ-1000 Display Screen Replacement: passo 2, imagem 2 %32 Casio CZ-1000 Display Screen Replacement: passo 2, imagem 3 %32
    • Using a Phillips #1 screwdriver, remove all 14 5.5 mm screws from the two motherboards.
    • These screws secure the motherboards to the keyboard assembly and the dial on the right side.
  3. Casio CZ-1000 Display Screen Replacement: passo 3, imagem 1 %32 Casio CZ-1000 Display Screen Replacement: passo 3, imagem 2 %32 Casio CZ-1000 Display Screen Replacement: passo 3, imagem 3 %32
    • Carefully cut the zip tie located in the right-hand corner using a pair of scissors or wire cutters.
    • Be sure to avoid cutting any nearby wires or components.
    • Gently slide all the plugs out of their sockets.
    • This will prevent them from catching on anything or damaging the connectors as you lift.
  4. Casio CZ-1000 Display Screen Replacement, Display Screen: passo 4, imagem 1 %32 Casio CZ-1000 Display Screen Replacement, Display Screen: passo 4, imagem 2 %32
    • Pull out the orange 24 pin connector.
    • Pull on the orange plastic piece and not the wires. Pulling on the wires can potentially damage the device.
  5. Casio CZ-1000 Display Screen Replacement: passo 5, imagem 1 %32 Casio CZ-1000 Display Screen Replacement: passo 5, imagem 2 %32
    • Remove the four 7.5 mm screws that are holding down the metal sheets using a Phillips #1 screwdriver.
    • Set the sheet to the side for now.
  6. Casio CZ-1000 Display Screen Replacement: passo 6, imagem 1 %32 Casio CZ-1000 Display Screen Replacement: passo 6, imagem 2 %32 Casio CZ-1000 Display Screen Replacement: passo 6, imagem 3 %32
    • Remove the four 5.5 mm screws from the corners of the display screen using a Phillips #1 screwdriver.
    • Lift the side of the display screen that is closer to you and then pull out the screen.
Conclusão
Ayman Benbrahim
Membro desde: 10/24/24
97 Reputação
Autoria de 1 guia
Equipe
Cuesta, Team 60-3, Krynen Fall 2024 Membro de Cuesta, Team 60-3, Krynen Fall 2024
CUESTA-KRYNEN-F24S60G3
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 33
