Ir para o conteúdo principal
Casio CZ-1000 Barrel Plug Replacement
O que você precisa
  1. Casio CZ-1000 Barrel Plug Replacement, Backplate: passo 1, imagem 1 %32 Casio CZ-1000 Barrel Plug Replacement, Backplate: passo 1, imagem 2 %32
    • Use a Phillips #1 screwdriver to remove the eleven 7.5 mm screws securing the back plate.
  2. Casio CZ-1000 Barrel Plug Replacement: passo 2, imagem 1 %32 Casio CZ-1000 Barrel Plug Replacement: passo 2, imagem 2 %32 Casio CZ-1000 Barrel Plug Replacement: passo 2, imagem 3 %32
    • Using a Phillips #1 screwdriver, remove all 14 5.5 mm screws from the two motherboards.
    • These screws secure the motherboards to the keyboard assembly and the dial on the right side.
  3. Casio CZ-1000 Barrel Plug Replacement: passo 3, imagem 1 %32 Casio CZ-1000 Barrel Plug Replacement: passo 3, imagem 2 %32 Casio CZ-1000 Barrel Plug Replacement: passo 3, imagem 3 %32
    • Carefully cut the zip tie located in the right-hand corner using a pair of scissors or wire cutters.
    • Be sure to avoid cutting any nearby wires or components.
    • Gently slide all the plugs out of their sockets.
    • This will prevent them from catching on anything or damaging the connectors as you lift.
  4. Casio CZ-1000 Barrel Plug Replacement, Barrel Plug: passo 4, imagem 1 %32
    • Clean the area around the barrel plug on the board using a lint-free cloth or a paper towel to remove dust or debris.
    • This ensures a clean working surface and better visibility of the solder joints.
  5. Casio CZ-1000 Barrel Plug Replacement: passo 5, imagem 1 %32 Casio CZ-1000 Barrel Plug Replacement: passo 5, imagem 2 %32
    • Hold the soldering iron against the solder joint for a few seconds to melt it, then gently pull the barrel plug out while the solder is liquid.
Conclusão
Jace Alexander
Membro desde: 10/24/24
181 Reputação
Autoria de 2 guias
Equipe
Cuesta, Team 60-3, Krynen Fall 2024 Membro de Cuesta, Team 60-3, Krynen Fall 2024
CUESTA-KRYNEN-F24S60G3
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 40
