Ir para o conteúdo principal
Casio CTK-501 Speaker Replacement
O que você precisa
  1. Casio CTK-501 Speaker Replacement, Bottom Panel: passo 1, imagem 1 %32 Casio CTK-501 Speaker Replacement, Bottom Panel: passo 1, imagem 2 %32
    • Flip the keyboard over so that the bottom is facing up.
    • Remove the twenty-seven 12 mm screws from the dark-grey panel using a Phillips #2 screwdriver.
  2. Casio CTK-501 Speaker Replacement: passo 2, imagem 1 %32
    • Remove the bottom panel by lifting and pulling it towards yourself.
  3. Casio CTK-501 Speaker Replacement: passo 3, imagem 1 %32 Casio CTK-501 Speaker Replacement: passo 3, imagem 2 %32
    • Flip open the top half of the keyboard.
    • Set the keyboard onto the bottom half with the internal parts facing up.
    • Be careful not to let the bottom drop.
  4. Casio CTK-501 Speaker Replacement, Speaker: passo 4, imagem 1 %32
    • Plug in the soldering iron and place somewhere safe to avoid burning yourself or causing a fire.
    • Completely unscrew and remove all four screws in the corners of the speaker.
  5. Casio CTK-501 Speaker Replacement: passo 5, imagem 1 %32
    • Pull the speaker out of the keyboard and set on a flat surface to solder safely.
  6. Casio CTK-501 Speaker Replacement: passo 6, imagem 1 %32
    • Be careful when removing the wires and avoid dripping solder on yourself or the keyboard.
    • Touch soldering iron to solder over the end of the wires, and when the solder melts, pull the wires away from the speaker.
    • Remove the speaker and replace with a new one.
  7. Casio CTK-501 Speaker Replacement: passo 7, imagem 1 %32
    • Strip the wires if you need more clean metal to solder to the speaker.
    • Use the soldering iron to melt the solder over the wire to connect them to the speaker.
  8. Casio CTK-501 Speaker Replacement: passo 8, imagem 1 %32
    • Completely screw in the screws back into the original positions on the corner of the speaker.
Conclusão
Uma outra pessoa concluiu este guia.
Jimmy Winne
Membro desde: 10/04/12
578 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team 9-16, Amido Fall 2012 Membro de Cal Poly, Team 9-16, Amido Fall 2012
CPSU-AMIDO-F12S9G16
Membros da 4
Autoria de 6 guias
Um comentário
I have a Casio ctk 691 Keyboard and it’s not Turning up is working is coming on but my volume slider is not working
Jacameron Bussey - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 6
Duração total: 6,431
