Ir para o conteúdo principal
Casio CTK-501 Keys Replacement
O que você precisa
  1. Casio CTK-501 Keys Replacement, Bottom Panel: passo 1, imagem 1 %32 Casio CTK-501 Keys Replacement, Bottom Panel: passo 1, imagem 2 %32
    • Flip the keyboard over so that the bottom is facing up.
    • Remove the twenty-seven 12 mm screws from the dark-grey panel using a Phillips #2 screwdriver.
  2. Casio CTK-501 Keys Replacement: passo 2, imagem 1 %32
    • Remove the bottom panel by lifting and pulling it towards yourself.
  3. Casio CTK-501 Keys Replacement: passo 3, imagem 1 %32 Casio CTK-501 Keys Replacement: passo 3, imagem 2 %32
    • Flip open the top half of the keyboard.
    • Set the keyboard onto the bottom half with the internal parts facing up.
    • Be careful not to let the bottom drop.
  4. Casio CTK-501 Keys Replacement, Keys: passo 4, imagem 1 %32
    • Completely unscrew and remove the screws holding the broken string of keys in place.
  5. Casio CTK-501 Keys Replacement: passo 5, imagem 1 %32
    • Pull up the top layer of white keys to remove them from the keyboard.
  6. Casio CTK-501 Keys Replacement: passo 6, imagem 1 %32
    • Pull up on the last layer of white keys to remove them.
  7. Casio CTK-501 Keys Replacement: passo 7, imagem 1 %32
    • Push the black keys toward the front of the keyboard and rotate them until they fall out of the keyboard.
Conclusão
7 outras pessoas executaram este guia.
Jimmy Winne
Membro desde: 10/04/12
578 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team 9-16, Amido Fall 2012 Membro de Cal Poly, Team 9-16, Amido Fall 2012
CPSU-AMIDO-F12S9G16
Membros da 4
Autoria de 6 guias
4 comentários
my ctk710 keybord circuit failure.... how to get new circuit in online plg help me
michael Akhil - Responder
Please do you know where to get Casio CTK700/720 (or compatible) complete Keys set replacement?
Thanks in advance!
Fred from Brasil
Luis Frederico - Responder
pliskers@optonline.net
Will replacing keys cure a rattle/chatter that I hear from my middle C and D keys when they are played?
pliskers - Responder
I want to repair my Roland Ex 20 keyboard keys because my middle position two keys are muted.
Jit Ghosh - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 25
Duração total: 25,207
