Introdução
Has your Casio A700 stopped working all of a sudden? Is the digital watch displaying nothing? Maybe it's time for a routine battery change! This guide will guide you through the process of changing the battery in a Casio A700. No prior experience is required, replacing your battery is much simpler than most people think and will give more usage out of your precious watch.
O que você precisa
Using a Philips #00 screwdriver, remove the four screws in the rear panel of the watch.
Remove the back panel from the watch.
Thank you for following my guide on the Casio A700! I hope you found it helpful!
