Ir para o conteúdo principal
Casio A158WA-1 Watch Circuit Board Replacement
O que você precisa
  1. Casio A158WA-1 Watch Circuit Board Replacement, Circuit Board: passo 1, imagem 1 %32
    • Remove the four screws from the back of the watch using a Phillips #00 screwdriver.
  2. Casio A158WA-1 Watch Circuit Board Replacement: passo 2, imagem 1 %32 Casio A158WA-1 Watch Circuit Board Replacement: passo 2, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Remove the back cover and the black rubber band with tweezers.
  3. Casio A158WA-1 Watch Circuit Board Replacement: passo 3, imagem 1 %32 Casio A158WA-1 Watch Circuit Board Replacement: passo 3, imagem 2 %32
    • Use a pair of tweezers to pull the small metal tab and remove the interior of the watch.
  4. Casio A158WA-1 Watch Circuit Board Replacement: passo 4, imagem 1 %32 Casio A158WA-1 Watch Circuit Board Replacement: passo 4, imagem 2 %32
    • Use a pair of tweezers to lift the metal clasps at each corner and remove the battery holder.
  5. Casio A158WA-1 Watch Circuit Board Replacement: passo 5, imagem 1 %32
    • Separate the LCD from the circuit board.
  6. Casio A158WA-1 Watch Circuit Board Replacement: passo 6, imagem 1 %32
    • Remember the position of the battery for reassembly.
    • Detach the battery from the circuit board.
  7. Casio A158WA-1 Watch Circuit Board Replacement: passo 7, imagem 1 %32
    • Attach the battery to the new circuit board.
  8. Casio A158WA-1 Watch Circuit Board Replacement: passo 8, imagem 1 %32 Casio A158WA-1 Watch Circuit Board Replacement: passo 8, imagem 2 %32 Casio A158WA-1 Watch Circuit Board Replacement: passo 8, imagem 3 %32
    • Place the new circuit board behind the LCD.
  9. Casio A158WA-1 Watch Circuit Board Replacement: passo 9, imagem 1 %32 Casio A158WA-1 Watch Circuit Board Replacement: passo 9, imagem 2 %32
    • Reattach the battery holder and push down on the clasps at each corner.
  10. Casio A158WA-1 Watch Circuit Board Replacement: passo 10, imagem 1 %32 Casio A158WA-1 Watch Circuit Board Replacement: passo 10, imagem 2 %32 Casio A158WA-1 Watch Circuit Board Replacement: passo 10, imagem 3 %32
    • Place the interior of the watch inside of the shell.
    • Put the rubber band and the lid back in their original position.
Linha de Chegada
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 11
Últimos 30 dias: 44
Duração total: 1,193
