Ir para o conteúdo principal
Introdução
This is a prerequisite-only guide! This guide is part of another procedure and is not meant to be used alone.
Peças
Nenhum componente especificado.
  1. Flip the PS4 upside-down with the back side facing towards you.
    • Flip the PS4 upside-down with the back side facing towards you.
  2. Use tweezers to remove the two stickers in the center of the back of the PS4 exposing two case screws. Use tweezers to remove the two stickers in the center of the back of the PS4 exposing two case screws. Use tweezers to remove the two stickers in the center of the back of the PS4 exposing two case screws.
    • Use tweezers to remove the two stickers in the center of the back of the PS4 exposing two case screws.
  3. Use tweezers to carefully remove the plastic screw covers in each corner, exposing two more case screws. Use tweezers to carefully remove the plastic screw covers in each corner, exposing two more case screws.
    • Use tweezers to carefully remove the plastic screw covers in each corner, exposing two more case screws.
  4. Remove the four 7.2 mm Torx security screws on the back of the PS4. Remove the four 7.2 mm Torx security screws on the back of the PS4.
    • Remove the four 7.2 mm Torx security screws on the back of the PS4.
  5. Use your thumbs to lift the lower case up and off the PS4. The lower case is held into place by plastic clips. You may need to use significant force to release the lower case.
    • Use your thumbs to lift the lower case up and off the PS4.
    • The lower case is held into place by plastic clips. You may need to use significant force to release the lower case.
  6. Use a pair of tweezers to pull the power supply cable straight out and disconnect the power supply unit from the motherboard. Use a pair of tweezers to pull the power supply cable straight out and disconnect the power supply unit from the motherboard.
    • Use a pair of tweezers to pull the power supply cable straight out and disconnect the power supply unit from the motherboard.
Conclusão
Sam Omiotek
Membro desde: 25/02/2019
30.634 Reputação
200 Guias de autoria
Equipe
iFixit Membro de iFixit
Community
140 Membros
17.046 Guias de autoria
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 5
Duração total: 172
