Ir para o conteúdo principal
Casdon Dyson Ball On/Off Switch Replacement
O que você precisa
  1. Casdon Dyson Ball On/Off Switch Replacement, Battery: passo 1, imagem 1 %32
    • Remove one 9.2mm (0.36 in) screw using the PH00 screwdriver.
    • Remove the battery cover by pulling it away from the vacuum once the 9.2mm (0.36 in) screw is removed.
  2. Casdon Dyson Ball On/Off Switch Replacement: passo 2, imagem 1 %32
    • Remove batteries from the vacuum by pulling them out and away from the vacuum.
  3. Casdon Dyson Ball On/Off Switch Replacement, On/Off Switch: passo 3, imagem 1 %32
    • Remove four 9.2mm (0.32 in) screws from the back of the vacuum using the PH00 screwdriver.
  4. Casdon Dyson Ball On/Off Switch Replacement: passo 4, imagem 1 %32
    • Remove the cover to the on/off switch by pulling up on the cover from the front of the vacuum.
  5. Casdon Dyson Ball On/Off Switch Replacement: passo 5, imagem 1 %32
    • Cut the two wires connected to the on/off switch using a set of wire cutters.
  6. Casdon Dyson Ball On/Off Switch Replacement: passo 6, imagem 1 %32
    • Remove the two 9.2mm (0.32 in) screws which hold the on/off switch to the vacuum using the PH00 screwdriver.
  7. Casdon Dyson Ball On/Off Switch Replacement: passo 7, imagem 1 %32
    • Remove the on/off switch by pulling it away from the vacuum with your fingers.
    • Replace the faulty on/off switch with the new on/off switch.
    • Solder the new on/off switch's wires to the vacuum's wires using a soldering station.
Conclusão
Seldon Price
Membro desde: 11/07/17
612 Reputação
Autoria de 5 guias
Equipe
IUPUI, Team S3-G5, Harley Fall 2017 Membro de IUPUI, Team S3-G5, Harley Fall 2017
IUPUI-HARLEY-F17S3G5
Membros da 3
Autoria de 10 guias
Um comentário
Great instructions but where can you purchase the on of switch and what is the part number?
debbyh1024 - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 24
Duração total: 2,064
