Ir para o conteúdo principal
Casdon Dyson Ball Battery Replacement
O que você precisa
  1. Casdon Dyson Ball Battery Replacement, Battery: passo 1, imagem 1 %32
    • Remove one 9.2mm (0.36 in) screw using the PH00 screwdriver.
    • Remove the battery cover by pulling it away from the vacuum once the 9.2mm (0.36 in) screw is removed.
  2. Casdon Dyson Ball Battery Replacement: passo 2, imagem 1 %32
    • Remove batteries from the vacuum by pulling them out and away from the vacuum.
    It take 4 C batteries. Hope this helps!
    Ladii Lee - Responder
Conclusão
Seldon Price
Membro desde: 11/07/17
612 Reputação
Autoria de 5 guias
Equipe
IUPUI, Team S3-G5, Harley Fall 2017 Membro de IUPUI, Team S3-G5, Harley Fall 2017
IUPUI-HARLEY-F17S3G5
Membros da 3
Autoria de 10 guias
2 comentários
I was looking for the kind of Batteries needed-this guide is really good but never says what type of Battery for the Dyson Ball;
Might be something to add??
Rob Dowdy - Responder
C batteries.
einst -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 8
Últimos 7 dias: 54
Últimos 30 dias: 212
Duração total: 19,328
