Ir para o conteúdo principal
Casablanca Intelli-Touch W-11 control testing
O que você precisa
  1. Casablanca Intelli-Touch W-11 control testing, Test wiring: passo 1, imagem 1 %32
    • Connect the hot side of an AC power cord to the Line In to the W-11
    • Connect the neutral side to a light bulb, lamp, etc.
    • Connect the Line Out of the WC-11 to the other side of the light bulb. Use a jumper wire.
    • Connect the oscilloscope leads to the hot and neutral sides of the light bulb.
    • Be sure that all the wiring is secure so that nothing shorts out during the testing.
    • Plug in the AC plug to a 110 volt outlet
  2. Casablanca Intelli-Touch W-11 control testing, Power test: passo 2, imagem 1 %32
    • Turn on the W-11 power switch.
    • Does the light turn on? If not, check your wiring.
    • Turn off the power, take apart the W-11 and test the power switch with a continuity tester/multimeter.
    • Set up the oscilloscope to observe the AC sine wave.
  3. Casablanca Intelli-Touch W-11 control testing, Test the light button: passo 3, imagem 1 %32
    • Press the Light button
    • Check the ossilloscope.
    • Do you see the small signal that appears on the rising side of the AC sine wave?
  4. Casablanca Intelli-Touch W-11 control testing, Test the fan button: passo 4, imagem 1 %32
    • Press the fan button
    • Do you see the signal on the falling side of the AC sine wave?
  5. Casablanca Intelli-Touch W-11 control testing, Test both switches: passo 5, imagem 1 %32
    • Press the fan and light switches simultaneously.
    • Do you see the signals on both the rising and falling sides of the AC sine wave?
Linha de Chegada
Wayne Seltzer
Membro desde: 11/09/10
1.732 Reputação
Autoria de 10 guias
Equipe
Global Fixers Membro de Global Fixers
Community
Membros da 45
Autoria de 700 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 11
Últimos 30 dias: 27
Duração total: 698
