Ir para o conteúdo principal
Carrera Mario Kart 8 Peach Axle Replacement Guide Replacement
O que você precisa
  1. Carrera Mario Kart 8 Peach Axle Replacement Guide Replacement, Axle Replacement Guide: passo 1, imagem 1 %32
    • Flip the car with the bottom side facing up.
    • Using a Philips screwdriver, remove the middle screw on the front axle while holding it the axle in place.
    • Carefully place the screw in a magnetic pad (or somewhere you won’t loose)
  2. Carrera Mario Kart 8 Peach Axle Replacement Guide Replacement: passo 2, imagem 1 %32
    • Place the new axle where on the curved side is pointed towards center.
    • Screw it into place but make sure it isn't too tight. The axle needs to able to move a bit.
  3. Carrera Mario Kart 8 Peach Axle Replacement Guide Replacement: passo 3, imagem 1 %32
    • Repeat the same steps for the back axle of the car but without concern of the curved part.
  4. Carrera Mario Kart 8 Peach Axle Replacement Guide Replacement: passo 4, imagem 1 %32
    • Place the new wheel into the car and attach the new screw
Conclusão
Kimberly Santos
Membro desde: 09/25/17
331 Reputação
Autoria de 3 guias
Equipe
USF Tampa, Team S3-G5, Cannon Fall 2017 Membro de USF Tampa, Team S3-G5, Cannon Fall 2017
USFT-CANNON-F17S3G5
Membros da 4
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 3
Últimos 30 dias: 16
Duração total: 830
