Introdução
A weak or damaged motor might be the reason your quadrocopter is unable to fly properly. This guide will show you how to replace any of the four motors
O que você precisa
Flip the quadrocopter over so that the underside of the device is facing up.
Unplug the battery cable from the socket on the quadrocopter.
Using the JIS #00 screwdriver, hold the rotor blade still and unscrew the 4.762mm screw in the center of the blade.
With the PH1 screwdriver, unscrew the four 7.1mm screws located underneath the quadrocopter.
Pull the base out and set the foam piece aside
