Ir para o conteúdo principal
Carlo Robelli CBW-4134CR Piezo Pickup Replacement
O que você precisa
  1. Carlo Robelli CBW-4134CR Piezo Pickup Replacement, Piezo Pickup: passo 1, imagem 1 %32 Carlo Robelli CBW-4134CR Piezo Pickup Replacement, Piezo Pickup: passo 1, imagem 2 %32 Carlo Robelli CBW-4134CR Piezo Pickup Replacement, Piezo Pickup: passo 1, imagem 3 %32
    • Unwind the low E guitar tuner with a guitar winder to loosen the string.
    • Cut the string above the sound hole using a string cutter.
  2. Carlo Robelli CBW-4134CR Piezo Pickup Replacement: passo 2, imagem 1 %32 Carlo Robelli CBW-4134CR Piezo Pickup Replacement: passo 2, imagem 2 %32 Carlo Robelli CBW-4134CR Piezo Pickup Replacement: passo 2, imagem 3 %32
    • Remove the low E string from the guitar tuner and remove the bridge pin.
  3. Carlo Robelli CBW-4134CR Piezo Pickup Replacement: passo 3, imagem 1 %32 Carlo Robelli CBW-4134CR Piezo Pickup Replacement: passo 3, imagem 2 %32 Carlo Robelli CBW-4134CR Piezo Pickup Replacement: passo 3, imagem 3 %32
    • Repeat Steps 1 and 2 for the rest of the guitar strings, removing all the pins and strings.
    • Remove the bridge saddle.
  4. Carlo Robelli CBW-4134CR Piezo Pickup Replacement: passo 4, imagem 1 %32 Carlo Robelli CBW-4134CR Piezo Pickup Replacement: passo 4, imagem 2 %32 Carlo Robelli CBW-4134CR Piezo Pickup Replacement: passo 4, imagem 3 %32
    • Find the preamp box inside the guitar soundhole and disconnect the piezo pickup only.
  5. Carlo Robelli CBW-4134CR Piezo Pickup Replacement: passo 5, imagem 1 %32 Carlo Robelli CBW-4134CR Piezo Pickup Replacement: passo 5, imagem 2 %32 Carlo Robelli CBW-4134CR Piezo Pickup Replacement: passo 5, imagem 3 %32
    • Inside the guitar, find the piezo pickup and push outward.
    • Once the pickup is sticking out, pull to remove it.
  6. Carlo Robelli CBW-4134CR Piezo Pickup Replacement: passo 6, imagem 1 %32 Carlo Robelli CBW-4134CR Piezo Pickup Replacement: passo 6, imagem 2 %32 Carlo Robelli CBW-4134CR Piezo Pickup Replacement: passo 6, imagem 3 %32
    • Grab the new piezo pickup and insert it in the designated hole, pressing firmly and ensuring it is neatly tucked in.
  7. Carlo Robelli CBW-4134CR Piezo Pickup Replacement: passo 7, imagem 1 %32 Carlo Robelli CBW-4134CR Piezo Pickup Replacement: passo 7, imagem 2 %32 Carlo Robelli CBW-4134CR Piezo Pickup Replacement: passo 7, imagem 3 %32
    • Once the piezo pickup is inside the guitar, connect the pickup to its proper input inside the guitar preamp.
  8. Carlo Robelli CBW-4134CR Piezo Pickup Replacement: passo 8, imagem 1 %32 Carlo Robelli CBW-4134CR Piezo Pickup Replacement: passo 8, imagem 2 %32 Carlo Robelli CBW-4134CR Piezo Pickup Replacement: passo 8, imagem 3 %32
    • Place the bridge saddle back in place.
    • Insert a new set of strings with guitar pins to ensure that the line is not pulled out when winding the new guitar strings.
  9. Carlo Robelli CBW-4134CR Piezo Pickup Replacement: passo 9, imagem 1 %32 Carlo Robelli CBW-4134CR Piezo Pickup Replacement: passo 9, imagem 2 %32 Carlo Robelli CBW-4134CR Piezo Pickup Replacement: passo 9, imagem 3 %32
    • Once all new strings are wound up, cut off the excess line for a neater look.
  10. Carlo Robelli CBW-4134CR Piezo Pickup Replacement: passo 10, imagem 1 %32
    • This is how the bridge should look once everything is back into place.
Conclusão
Having a new piezo pickup will heavily improve the sound quality sent from your guitar to the guitar amplifier, recording interface, PA system, or headphones.
Bryant Castor
Membro desde: 04/04/22
181 Reputação
Autoria de 1 guia
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 11
Duração total: 374
