Introdução
This guide will instruct you on the proper method to replace the handle of the Caribou Coffee CC-EKV8SS7 coffee maker.
Use a Phillips-Head (PH1) screwdriver to loosen the two screws that attach the handle to the pot. Use a Phillips-Head (PH1) screwdriver to loosen the two screws that attach the handle to the pot. Use a Phillips-Head (PH1) screwdriver to loosen the two screws that attach the handle to the pot.
  • Use a Phillips-Head (PH1) screwdriver to loosen the two screws that attach the handle to the pot.
Adicionar comentário
Detach the handle by sliding it off the metal arm of the coffee pot. Detach the handle by sliding it off the metal arm of the coffee pot.
  • Detach the handle by sliding it off the metal arm of the coffee pot.
Conclusão
2 outras pessoas concluíram este guia.
Lucas Baesler
245 reputação
2 Guides authored
Equipe
UW Tacoma, Team S1-G3, Liner Summer 2017 Membro de UW Tacoma, Team S1-G3, Liner Summer 2017
UWT-LINER-SU17S1G3
4 Membros
4 Guides authored
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Todo: 120
