Introdução
The Turbine is integral to the Ventilator's function. A possible cause of failure during the delivered volume test is the turbine assembly itself. In this case the Turbine assembly must be removed, and either replaced with P/N 16349 or sent to manufacturer for Re-Characterization. This guide will walk through the necessary steps to remove the turbine assembly.
O que você precisa
Passo 1 Cardinal Health Vela Ventilator Power Cable Removal
Cuidado: as etapas de 1 a 2 são provenientes de um guia marcado como em andamento.
Use a screwdriver to remove the two Phillips pan-head screws at the top of the plug guard.
Remove the four Phillips #0 screws on the back side of the ventilator.
Passo 6 Cardinal Health Vela Ventilator Battery Tray Removal
Cuidado: as etapas de 6 a 8 são provenientes de um guia marcado como em andamento.
Use your Phillips screwdriver to unscrew the 4 Phillips pan head screws positioned on each side of the battery tray.
Passo 13 Blender Assembly P/N 16358A
Cuidado: as etapas de 13 a 21 são provenientes de um guia marcado como em andamento.
If the rear panel is installed, remove the high and low pressure oxygen fittings from the rear panel using your 3/4" wrench. NOTE: the high pressure fitting is located above the low pressure fitting
Disconnect the main wire harness connector at P2 on the Turbine Driver PCBA
Uma outra pessoa concluiu este guia.
