Ir para o conteúdo principal
Conserte seus objetos
Direito de executar reparos
Loja
Introdução
In this guide, you will be instructed on how to adjust and synchronize the output of the two carburetors.
  1. Use a 3/8 socket wrench to loosen the retaining bolts on the air cleaner. Rotate the air cleaner so that the throats of both carburetors are clear. Now you will be able to adjust them.
    • Use a 3/8 socket wrench to loosen the retaining bolts on the air cleaner.
    • Rotate the air cleaner so that the throats of both carburetors are clear. Now you will be able to adjust them.
    • Start the engine
  2. Allow time for the engine to warm up completely Attach carburetor synchronization tool to  one of the carburetors
    • Allow time for the engine to warm up completely
    • Attach carburetor synchronization tool to one of the carburetors
    • Observe the relative reading, and remember it.
    • This reading is a measurement of the airflow speed
  3. Set the  synchronization device on the other carburetor.
    • Set the synchronization device on the other carburetor.
    • Using a Flathead screw-driver, twist the idle speed screw in to raise the flow, and out to lower it.
    • Recheck both carburetors and adjust as needed to get the flow as equal as possible.
  4. Now, the idle mixture screws must be adjusted. It is important that when the screws are adjusted they are adjusted the same amount in the same direction.
    • Now, the idle mixture screws must be adjusted.
    • It is important that when the screws are adjusted they are adjusted the same amount in the same direction.
    • Turn both screws in, or out an 1/8 or a turn at a time until the fastest idle speed is achieved.
    • Before proceeding with this step you should have already checked your ignition timing, if you have not do it now, and then continue from here.
  5. Finally, raise or lower the idle speed screws until the idle speed is about 550 RPM
    • Finally, raise or lower the idle speed screws until the idle speed is about 550 RPM
    • Once more, it is important to adjust the screws the same amount.
    • Rotate the aircleaner back to its original position, and re-tighten the 3/8 nuts on the retainers
Conclusão
Congratulations, your Corvair should now idle properly. If the Carburetors are still not operating properly, then the linkage is not synchronized, or they are in need of repair or rebuild. (A linkage adjustment and rebuild guide will be made soon!)
25 outras pessoas concluíram este guia.
Noah
Membro desde: 03/10/2012
523 Reputação
4 Guias de autoria
Equipe
Cal Poly, Team 6-33, Regan Fall 2012 Membro de Cal Poly, Team 6-33, Regan Fall 2012
CPSU-REGAN-F12S6G33
3 Membros
7 Guias de autoria
Bonjour,
Ma corvair a 4 carburateurs.
Est-ce que le ralenti se règle individuellement sur chaque ?
Merci
Stéphane Decottignies - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 24
Últimos 7 dias: 147
Últimos 30 dias: 518
Duração total: 47,917
