Ir para o conteúdo principal
Carburetor Disassembly
O que você precisa
  1. Carburetor Disassembly, Remove air filter + housing: passo 1, imagem 1 %32 Carburetor Disassembly, Remove air filter + housing: passo 1, imagem 2 %32 Carburetor Disassembly, Remove air filter + housing: passo 1, imagem 3 %32
    • Use a 5/16 socket or flat head screwdriver to remove the first bolt. Pull the cover off and remove the air filter.
    • Remove the 3 bolts using a 5/16 socket. In addition, pull the breather hose off the assembly at the bottom left. Now pull the cover off.
  2. Carburetor Disassembly, Remove carburetor: passo 2, imagem 1 %32 Carburetor Disassembly, Remove carburetor: passo 2, imagem 2 %32 Carburetor Disassembly, Remove carburetor: passo 2, imagem 3 %32
    • Remove the two bolts holding the carburetor to the engine with a 3/8 socket or wrench.
    • Remove the spring boxed in red from the hole. Pull to left of carburetor, towards the link the other end of the spring is around.
    • The link will be connected to the carburetor. Pull the carburetor off in an "S" motion and remove it.
Conclusão
Jacob Micallef
Membro desde: 03/06/17
993 Reputação
Autoria de 7 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 8
Últimos 30 dias: 40
Ao todo: 1,526
