Ir para o conteúdo principal
Carburetor Cleaning
O que você precisa
  1. Carburetor Cleaning, Air Filter: passo 1, imagem 1 %32 Carburetor Cleaning, Air Filter: passo 1, imagem 2 %32 Carburetor Cleaning, Air Filter: passo 1, imagem 3 %32
    • Before starting, ensure that the engine is not running and is not hot.
    • Pull the tab until the filter cover opens. Remove the filter cover.
    • Note that the bottom of the cover is hinged.
  2. Carburetor Cleaning: passo 2, imagem 1 %32
    • Remove the air filter.
    • The air filter will be either an oily sponge, or an accordion-folded fabric.
    • Note that the air filter is saturated with oil. Wear gloves and use paper towels to avoid creating a mess.
  3. Carburetor Cleaning, Carburetor Cleaning: passo 3, imagem 1 %32 Carburetor Cleaning, Carburetor Cleaning: passo 3, imagem 2 %32 Carburetor Cleaning, Carburetor Cleaning: passo 3, imagem 3 %32
    • Locate the four bolts holding the air filter housing to the engine. Remove these bolts using the ratchet driver and the appropriately sized socket.
    • Remove the 1/4" bolts.
    • Remove the 5/16" bolts.
  4. Carburetor Cleaning: passo 4, imagem 1 %32 Carburetor Cleaning: passo 4, imagem 2 %32
    • Lift away the air filter housing.
    • Note that the housing is still attached to the engine via a bendable plastic rod.
  5. Carburetor Cleaning: passo 5, imagem 1 %32
    • Spray carburetor cleaner into the open carburetor.
    • You may want to wear gloves for this step, as carburetor cleaner is harmful if applied to the skin.
Conclusão
Ethan Narad
Membro desde: 04/19/18
529 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team S25-G15, Maness Spring 2018 Membro de Cal Poly, Team S25-G15, Maness Spring 2018
CPSU-MANESS-S18S25G15
Membros da 4
Autoria de 7 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 5
Últimos 30 dias: 6
Duração total: 1,675
