Introdução
If your small gas engine is running sluggishly or smoking, it's possible that the carburetor is clogged or dirty. This guide will provide instructions on how to access and clean the carburetor.
O que você precisa
Locate the four bolts holding the air filter housing to the engine. Remove these bolts using the ratchet driver and the appropriately sized socket.
Remove the 1/4" bolts.
Remove the 5/16" bolts.
