Ir para o conteúdo principal
Carburetor Adjustment
O que você precisa
  1. Carburetor Adjustment, Install the inductive pickup lead: passo 1, imagem 1 %32 Carburetor Adjustment, Install the inductive pickup lead: passo 1, imagem 2 %32
    • Feed the inductive pickup lead wire through one of the two holes in the lower-left corner of the tachometer.
    • Bend the wire around and feed it through the second hole, then pull it tight.
  2. Carburetor Adjustment, Attach the tachometer to the spark plug wire: passo 2, imagem 1 %32 Carburetor Adjustment, Attach the tachometer to the spark plug wire: passo 2, imagem 2 %32
    • Clamp the inductive pickup lead alligator clip onto the spark plug wire.
    • Make sure the inductive pickup lead wire is not touching anything except the tachometer.
  3. Carburetor Adjustment, Start the motor: passo 3, imagem 1 %32 Carburetor Adjustment, Start the motor: passo 3, imagem 2 %32
    • Wear ear protection for the remainder of the procedure.
    • Start the motor and let it run for two minutes to ensure it reaches operating temperature.
  4. Carburetor Adjustment, Open the choke: passo 4, imagem 1 %32 Carburetor Adjustment, Open the choke: passo 4, imagem 2 %32 Carburetor Adjustment, Open the choke: passo 4, imagem 3 %32
    • Make sure the choke is fully in the open position.
  5. Carburetor Adjustment: passo 5, imagem 1 %32 Carburetor Adjustment: passo 5, imagem 2 %32
    • Use a Phillips screwdriver to adjust the carburetor idle screw until the tachometer reads as close to 3100 RPM as possible:
    • Turn the idle screw clockwise to increase RPM
    • Turn the idle screw counterclockwise to decrease RPM
    • Once the idle has been set, shut off the motor and disconnect the tachometer.
Conclusão
The procedure is complete, no further action is required.
Sam Omiotek
Membro desde: 02/25/19
67.876 Reputação
Autoria de 288 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 18
Duração total: 331
