Ir para o conteúdo principal
Car Seat Belt Stopper Replacement
O que você precisa
    1. Car Seat Belt Stopper Replacement, Car Seat Belt Stopper: passo 1, imagem 1 %32
      • Use a cloth to wipe away any debris from the area.
      Pergunte ao FixBot
      Comentar
    2. Car Seat Belt Stopper Replacement: passo 2, imagem 1 %32
      • Find the existing hole for the seat belt stopper or choose a different location that is better for you.
      • Separate the replacement stopper if it has come assembled.
      Pergunte ao FixBot
      Comentar
    3. Car Seat Belt Stopper Replacement: passo 3, imagem 1 %32
      • Before you begin, make sure that the seat belt buckle is pushed above the hole where you are installing the new seat belt stopper.
      • Push the side of the seat belt button with the needle or point into your desired location.
      • It may require a small amount of force.
      Pergunte ao FixBot
      Comentar
    4. Car Seat Belt Stopper Replacement: passo 4, imagem 1 %32
      • Take the other half of button stopper and slide it onto the pin on the other side of the belt.
      • Fasten the two parts of the button together and squeeze for a secure fit.
      • You may hear a "snap" or "click" when they are fastened together.
      Pergunte ao FixBot
      Comentar
    5. Car Seat Belt Stopper Replacement: passo 5, imagem 1 %32
      • Check the position of the replacement stopper for a comfortable fit.
      Pergunte ao FixBot
      Comentar
    6. Car Seat Belt Stopper Replacement: passo 6, imagem 1 %32
      • Now you can use the seat belt buckle without it falling down!
      Pergunte ao FixBot
      Comentar
Conclusão
Changing your positioning of replacement can be used to your liking.
Uma outra pessoa concluiu este guia.
Zhong Chu
Membro desde: 04/23/24
137 Reputação
Autoria de 1 guia
Equipe
UC Davis, Team 4-1, Whithaus Spring 2024 Membro de UC Davis, Team 4-1, Whithaus Spring 2024
UCD-WHITHAUS-S24S4G1
3 Membros
Autoria de 10 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 39
Últimos 30 dias: 172
Ao todo: 3,261
