Ir para o conteúdo principal
Cap Restoration
O que você precisa
  1. Cap Restoration, Cap Restoration: passo 1, imagem 1 %32 Cap Restoration, Cap Restoration: passo 1, imagem 2 %32 Cap Restoration, Cap Restoration: passo 1, imagem 3 %32
    • Wash the cap using an old toothbrush to remove residue and stains.
    • You can use dish soap or detergent to assist with the cleaning process.
  2. Cap Restoration: passo 2, imagem 1 %32
    • Pat dry the cap with a towel to remove any excess water.
  3. Cap Restoration: passo 3, imagem 1 %32 Cap Restoration: passo 3, imagem 2 %32
    • Apply the hairspray to the front and inside of the cap.
  4. Cap Restoration: passo 4, imagem 1 %32
    • Place plastic bags into the cap ensuring enough bags are used to give the cap some shape.
  5. Cap Restoration: passo 5, imagem 1 %32 Cap Restoration: passo 5, imagem 2 %32
    • Use a bowl or small pot to add pressure to the plastic bags and hold them in place.
    • Tighten the clip or snaps of the cap to fix the pot/bowl and plastic bags into place.
  6. Cap Restoration: passo 6, imagem 1 %32
    • Set the cap aside to dry naturally. You can use an indoor fan to assist with this process.
    • Do not leave outside or near heater to dry.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 9
Últimos 7 dias: 59
Últimos 30 dias: 317
Duração total: 18,122
