Ir para o conteúdo principal
Canon ZR70MC Speaker Replacement
O que você precisa
  1. Canon ZR70MC Speaker Replacement, Front Panel: passo 1, imagem 1 %32 Canon ZR70MC Speaker Replacement, Front Panel: passo 1, imagem 2 %32
    • Unscrew the 3.35mm screw.
  2. Canon ZR70MC Speaker Replacement: passo 2, imagem 1 %32
    • Turn the ZR70MC so that you can see the bottom of the camcorder.
    • Unscrew the 3.35 mm located in the top left portion of the camera.
  3. Canon ZR70MC Speaker Replacement: passo 3, imagem 1 %32 Canon ZR70MC Speaker Replacement: passo 3, imagem 2 %32 Canon ZR70MC Speaker Replacement: passo 3, imagem 3 %32
    • Turn the camera on the side and remove the cover for the audio inputs. There is a 2.65 mm screw located behind the cover.
    • Remove the 2.65 mm screw.
  4. Canon ZR70MC Speaker Replacement: passo 4, imagem 1 %32 Canon ZR70MC Speaker Replacement: passo 4, imagem 2 %32 Canon ZR70MC Speaker Replacement: passo 4, imagem 3 %32
    • Remove the cover located on the front of the camcorder and remove the cover by pulling on the bottom groove.
    • Locate and remove the two 3.35 mm screws.
  5. Canon ZR70MC Speaker Replacement: passo 5, imagem 1 %32 Canon ZR70MC Speaker Replacement: passo 5, imagem 2 %32
    • Turn the camcorder so that the bottom is facing up and open the tape cassette compartment.
    • There is one 3.35 mm screw located under the tape cassette panel on the front left side of the camcorder. Remove the screw.
  6. Canon ZR70MC Speaker Replacement: passo 6, imagem 1 %32 Canon ZR70MC Speaker Replacement: passo 6, imagem 2 %32 Canon ZR70MC Speaker Replacement: passo 6, imagem 3 %32
    • Now that all of the screws are removed, remove the front panel by gently pulling on the front panel.
    • The speaker will be connected to the main body by a wire. Be careful not to damage this wire.
  7. Canon ZR70MC Speaker Replacement: passo 7, imagem 1 %32 Canon ZR70MC Speaker Replacement: passo 7, imagem 2 %32 Canon ZR70MC Speaker Replacement: passo 7, imagem 3 %32
    • Use tweezers to gently pull the speaker wire from the main body of the camcorder.
    • Pull the front panel completely away from the main body of the camcorder.
  8. Canon ZR70MC Speaker Replacement, Speaker: passo 8, imagem 1 %32 Canon ZR70MC Speaker Replacement, Speaker: passo 8, imagem 2 %32 Canon ZR70MC Speaker Replacement, Speaker: passo 8, imagem 3 %32
    • Take the front panel and remove the three 2.75 mm screws from the metal plate.
  9. Canon ZR70MC Speaker Replacement: passo 9, imagem 1 %32 Canon ZR70MC Speaker Replacement: passo 9, imagem 2 %32 Canon ZR70MC Speaker Replacement: passo 9, imagem 3 %32
    • Remove the metal plate. This metal plate protects the black speaker holder.
  10. Canon ZR70MC Speaker Replacement: passo 10, imagem 1 %32 Canon ZR70MC Speaker Replacement: passo 10, imagem 2 %32 Canon ZR70MC Speaker Replacement: passo 10, imagem 3 %32
    • Remove the black speaker holder from the front panel. This holds the individual speakers.
  11. Canon ZR70MC Speaker Replacement: passo 11, imagem 1 %32 Canon ZR70MC Speaker Replacement: passo 11, imagem 2 %32 Canon ZR70MC Speaker Replacement: passo 11, imagem 3 %32
    • Remove the individual speakers from the black speaker holder.
Conclusão
khalid clarke
Membro desde: 09/26/17
824 Reputação
Autoria de 7 guias
Equipe
USF Tampa, Team S13-G2, Boczar Fall 2017 Membro de USF Tampa, Team S13-G2, Boczar Fall 2017
USFT-BOCZAR-F17S13G2
Membros da 3
Autoria de 14 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 116
