Ir para o conteúdo principal
Canon Vixia HF20 Camcorder Strap Replacement
  1. Canon Vixia HF20 Camcorder Strap Replacement, Camcorder Strap: passo 1, imagem 1 %32 Canon Vixia HF20 Camcorder Strap Replacement, Camcorder Strap: passo 1, imagem 2 %32 Canon Vixia HF20 Camcorder Strap Replacement, Camcorder Strap: passo 1, imagem 3 %32
    • Un-velcro the camcorder strap.
    • Remove the strap from the first hole by pulling towards the front of the camcorder, continue pulling the strap through until it is removed from second anchor point as well.
    • There should now be two empty anchor points.
  2. Canon Vixia HF20 Camcorder Strap Replacement: passo 2, imagem 1 %32 Canon Vixia HF20 Camcorder Strap Replacement: passo 2, imagem 2 %32 Canon Vixia HF20 Camcorder Strap Replacement: passo 2, imagem 3 %32
    • Re-insert the new Velcro strap through the back anchor hole in the direction of the arrow (toward the battery end of the camcorder).
    • Then through the padded hand strap in direction of the arrow.
    • Lastly, pull the strap through the front anchor hole adjusting for your grip.
  3. Canon Vixia HF20 Camcorder Strap Replacement: passo 3, imagem 1 %32
    • Once the fit is adjusted, secure by closing the padded strap.
Linha de Chegada
Uma outra pessoa concluiu este guia.
Taylor Morris
Membro desde: 03/05/15
225 Reputação
Autoria de 2 guias
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 14
Duração total: 547
