Ir para o conteúdo principal
Canon Vixia HF20 Attachment Port for Optional Accessory Replacement
O que você precisa
  1. Canon Vixia HF20 Attachment Port for Optional Accessory Replacement, Attachment Port for Optional Accessory: passo 1, imagem 1 %32
    • Remove the mini advanced shoe from the top of the camcorder.
  2. Canon Vixia HF20 Attachment Port for Optional Accessory Replacement: passo 2, imagem 1 %32
    • Unscrew the four 6 millimeter screws with the Phillips screwdriver.
  3. Canon Vixia HF20 Attachment Port for Optional Accessory Replacement: passo 3, imagem 1 %32
    • Carefully remove the silver plate with needle nose pliers.
    • Clean the silver plate with isopropyl alcohol and a cotton swab to remove any debris.
  4. Canon Vixia HF20 Attachment Port for Optional Accessory Replacement: passo 4, imagem 1 %32
    • Reinsert the silver plate and the four 6 mm screws and screw them securely into their holes.
Conclusão
Uma outra pessoa concluiu este guia.
Taylor Morris
Membro desde: 03/05/15
225 Reputação
Autoria de 2 guias
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Duração total: 475
