Ir para o conteúdo principal
Canon Vixia HF S10 Camcorder Audio Replacement
O que você precisa
  1. Canon Vixia HF S10 Camcorder Audio Replacement, Audio: passo 1, imagem 1 %32 Canon Vixia HF S10 Camcorder Audio Replacement, Audio: passo 1, imagem 2 %32 Canon Vixia HF S10 Camcorder Audio Replacement, Audio: passo 1, imagem 3 %32
    • Turn the camcorder upside down and remove the three 3x4 mm Phillips screws securing the black plastic case.
    • Flip open the LCD screen.
    • Remove the three 3x4 mm Phillips screws securing the black panel plastic case.
  2. Canon Vixia HF S10 Camcorder Audio Replacement: passo 2, imagem 1 %32 Canon Vixia HF S10 Camcorder Audio Replacement: passo 2, imagem 2 %32 Canon Vixia HF S10 Camcorder Audio Replacement: passo 2, imagem 3 %32
    • From the inner corner in between the panel and the LCD screen, remove the two 2x2.5 mm Phillips screws and the 3x4 mm Phillips screw.
    • Remove the black plastic covering with your fingers. Underneath the covering, you will find a screw hinge.
    • Remove the 2x2.25 mm Phillips screw located at the top of the screw hinge.
  3. Canon Vixia HF S10 Camcorder Audio Replacement: passo 3, imagem 1 %32 Canon Vixia HF S10 Camcorder Audio Replacement: passo 3, imagem 2 %32 Canon Vixia HF S10 Camcorder Audio Replacement: passo 3, imagem 3 %32
    • Using your fingers, remove the panel from the base of the camcorder.
    • After removing the panel, remove the two 2x2.25 mm Phillips screws located at the top right of the inside of the panel.
    • Using one hand, gently move the silver piece holding the speaker down while using the other hand to remove the speaker.
Conclusão
Clint
Membro desde: 03/03/15
101 Reputação
Autoria de 1 guia
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 7
Duração total: 403
