Ir para o conteúdo principal
Canon Vixia HF R70 Side Panel Replacement
O que você precisa
  1. Canon Vixia HF R70 Side Panel Replacement, Battery: passo 1, imagem 1 %32
    • Power off and unplug the device.
    • Position the camera so that the battery is facing you.
  2. Canon Vixia HF R70 Side Panel Replacement: passo 2, imagem 1 %32
    • Locate the latch on the bottom edge of the camera.
    • Hold the battery into place and gently push down on the latch towards the lens.
  3. Canon Vixia HF R70 Side Panel Replacement: passo 3, imagem 1 %32 Canon Vixia HF R70 Side Panel Replacement: passo 3, imagem 2 %32
    • While holding down the latch, remove the battery by pulling it out of the device.
  4. Canon Vixia HF R70 Side Panel Replacement, Wrist Strap: passo 4, imagem 1 %32
    • Position the camcorder so that the wrist strap is facing you.
    • Locate the loose end of the strap.
  5. Canon Vixia HF R70 Side Panel Replacement: passo 5, imagem 1 %32
    • Gently pull on the loose end to separate the Velcro.
  6. Canon Vixia HF R70 Side Panel Replacement: passo 6, imagem 1 %32
    • Locate the "slot" on bottom right corner of the camcorder where the strap loops through.
    • Pull the strap through the loop.
  7. Canon Vixia HF R70 Side Panel Replacement: passo 7, imagem 1 %32 Canon Vixia HF R70 Side Panel Replacement: passo 7, imagem 2 %32
    • Pull the strap through the leather cushion.
  8. Canon Vixia HF R70 Side Panel Replacement: passo 8, imagem 1 %32
    • Pull the strap through the slot on the left side of the camcorder.
  9. Canon Vixia HF R70 Side Panel Replacement, Side Panel: passo 9, imagem 1 %32 Canon Vixia HF R70 Side Panel Replacement, Side Panel: passo 9, imagem 2 %32
    • Position the camcorder so that the side panel is facing you.
    • Locate the two 6mm Phillips #00 screws on the side panel.
    • Remove the the screws using a screwdriver with a Phillips #00 head.
  10. Canon Vixia HF R70 Side Panel Replacement: passo 10, imagem 1 %32 Canon Vixia HF R70 Side Panel Replacement: passo 10, imagem 2 %32 Canon Vixia HF R70 Side Panel Replacement: passo 10, imagem 3 %32
    • Turn the camcorder so that the bottom is facing you.
    • Using your screwdriver, locate and remove the four 6mm Phillips #00 screws connecting the side panel to the bottom of the camcorder.
  11. Canon Vixia HF R70 Side Panel Replacement: passo 11, imagem 1 %32 Canon Vixia HF R70 Side Panel Replacement: passo 11, imagem 2 %32
    • Gently remove the side panel by pushing it up from the bottom.
Conclusão
Thomas Rogienski
Membro desde: 02/28/17
501 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team S2-G2, Nance Spring 2017 Membro de USF Tampa, Team S2-G2, Nance Spring 2017
USFT-NANCE-S17S2G2
Membros da 4
Autoria de 14 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 9
Duração total: 418
