Introdução
The side panel is the non-glossy part of the camcorder that protects the inner components. It is the first part of the camera that needs to be removed before any internal parts are replaced. Use this guide to remove the side panel to your Canon Vixia HF R70.
O que você precisa
Power off and unplug the device.
Position the camera so that the battery is facing you.
Position the camcorder so that the wrist strap is facing you.
Locate the loose end of the strap.
Position the camcorder so that the side panel is facing you.
Locate the two 6mm Phillips #00 screws on the side panel.
Remove the the screws using a screwdriver with a Phillips #00 head.
