Ir para o conteúdo principal
Canon Vixia HF R70 SD Card Replacement
  1. Canon Vixia HF R70 SD Card Replacement, SD Card: passo 1, imagem 1 %32 Canon Vixia HF R70 SD Card Replacement, SD Card: passo 1, imagem 2 %32 Canon Vixia HF R70 SD Card Replacement, SD Card: passo 1, imagem 3 %32
    • Open the screen compartment.
    • Position the camcorder so that the screen is facing you.
  2. Canon Vixia HF R70 SD Card Replacement: passo 2, imagem 1 %32 Canon Vixia HF R70 SD Card Replacement: passo 2, imagem 2 %32
    • Find the SD card compartment.
    • Place your finger under the slot and gently slide it forward to open the compartment.
  3. Canon Vixia HF R70 SD Card Replacement: passo 3, imagem 1 %32 Canon Vixia HF R70 SD Card Replacement: passo 3, imagem 2 %32
    • Gently push on the SD card until you hear a "click". The SD card should pop out.
    • Remove the old SD card by pulling it out.
Conclusão
Thomas Rogienski
Membro desde: 02/28/17
501 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team S2-G2, Nance Spring 2017 Membro de USF Tampa, Team S2-G2, Nance Spring 2017
USFT-NANCE-S17S2G2
Membros da 4
Autoria de 14 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 8
Duração total: 244
