Ir para o conteúdo principal
Canon Vixia HF R70 Lens Replacement
O que você precisa
  1. Canon Vixia HF R70 Lens Replacement, Battery: passo 1, imagem 1 %32
    • Power off and unplug the device.
    • Position the camera so that the battery is facing you.
  2. Canon Vixia HF R70 Lens Replacement: passo 2, imagem 1 %32
    • Locate the latch on the bottom edge of the camera.
    • Hold the battery into place and gently push down on the latch towards the lens.
  3. Canon Vixia HF R70 Lens Replacement: passo 3, imagem 1 %32 Canon Vixia HF R70 Lens Replacement: passo 3, imagem 2 %32
    • While holding down the latch, remove the battery by pulling it out of the device.
  4. Canon Vixia HF R70 Lens Replacement, Wrist Strap: passo 4, imagem 1 %32
    • Position the camcorder so that the wrist strap is facing you.
    • Locate the loose end of the strap.
  5. Canon Vixia HF R70 Lens Replacement: passo 5, imagem 1 %32
    • Gently pull on the loose end to separate the Velcro.
  6. Canon Vixia HF R70 Lens Replacement: passo 6, imagem 1 %32
    • Locate the "slot" on bottom right corner of the camcorder where the strap loops through.
    • Pull the strap through the loop.
  7. Canon Vixia HF R70 Lens Replacement: passo 7, imagem 1 %32 Canon Vixia HF R70 Lens Replacement: passo 7, imagem 2 %32
    • Pull the strap through the leather cushion.
  8. Canon Vixia HF R70 Lens Replacement: passo 8, imagem 1 %32
    • Pull the strap through the slot on the left side of the camcorder.
  9. Canon Vixia HF R70 Lens Replacement, Side Panel: passo 9, imagem 1 %32 Canon Vixia HF R70 Lens Replacement, Side Panel: passo 9, imagem 2 %32
    • Position the camcorder so that the side panel is facing you.
    • Locate the two 6mm Phillips #00 screws on the side panel.
    • Remove the the screws using a screwdriver with a Phillips #00 head.
  10. Canon Vixia HF R70 Lens Replacement: passo 10, imagem 1 %32 Canon Vixia HF R70 Lens Replacement: passo 10, imagem 2 %32 Canon Vixia HF R70 Lens Replacement: passo 10, imagem 3 %32
    • Turn the camcorder so that the bottom is facing you.
    • Using your screwdriver, locate and remove the four 6mm Phillips #00 screws connecting the side panel to the bottom of the camcorder.
  11. Canon Vixia HF R70 Lens Replacement: passo 11, imagem 1 %32 Canon Vixia HF R70 Lens Replacement: passo 11, imagem 2 %32
    • Gently remove the side panel by pushing it up from the bottom.
  12. Canon Vixia HF R70 Lens Replacement, Top Panel: passo 12, imagem 1 %32 Canon Vixia HF R70 Lens Replacement, Top Panel: passo 12, imagem 2 %32
    • Disconnect the wires by inserting the plastic opening tool into the small slit.
    • Begin to push upward with the plastic opening tool, disconnecting the two compartments.
  13. Canon Vixia HF R70 Lens Replacement: passo 13, imagem 1 %32 Canon Vixia HF R70 Lens Replacement: passo 13, imagem 2 %32 Canon Vixia HF R70 Lens Replacement: passo 13, imagem 3 %32
    • Disconnect the four ZIF connectors by grasping the connector firmly and pulling gently.
  14. Canon Vixia HF R70 Lens Replacement: passo 14, imagem 1 %32
    • Locate and remove the two 3mm Phillips #00 screws on the side of the camera where the side panel was removed.
  15. Canon Vixia HF R70 Lens Replacement: passo 15, imagem 1 %32
    • Turn the camera over to the side with the LCD screen, and open the screen.
    • Locate and remove the three 5mm Phillips #00 screws holding the top panel in place.
  16. Canon Vixia HF R70 Lens Replacement: passo 16, imagem 1 %32 Canon Vixia HF R70 Lens Replacement: passo 16, imagem 2 %32 Canon Vixia HF R70 Lens Replacement: passo 16, imagem 3 %32
    • Pull the panel up and away until it is removed completely.
  17. Canon Vixia HF R70 Lens Replacement, Shutter: passo 17, imagem 1 %32 Canon Vixia HF R70 Lens Replacement, Shutter: passo 17, imagem 2 %32 Canon Vixia HF R70 Lens Replacement, Shutter: passo 17, imagem 3 %32
    • There are three 5mm Phillips #00 screws that need to be removed - one on the top, one on the side, and one on the bottom.
    • Locate and remove the screw on the top side of the camera.
    • Locate and remove the screw on the side of the camera where you previously removed the side panel.
    • Locate and remove the screw on the bottom of the camera.
  18. Canon Vixia HF R70 Lens Replacement: passo 18, imagem 1 %32 Canon Vixia HF R70 Lens Replacement: passo 18, imagem 2 %32
    • Pull the entire shutter away from the body of the camera to remove it.
  19. Canon Vixia HF R70 Lens Replacement, Lens: passo 19, imagem 1 %32 Canon Vixia HF R70 Lens Replacement, Lens: passo 19, imagem 2 %32
    • With the front of the camera facing you, locate and remove the three 5mm Phillips #00 screws that hold the lens in place.
  20. Canon Vixia HF R70 Lens Replacement: passo 20, imagem 1 %32 Canon Vixia HF R70 Lens Replacement: passo 20, imagem 2 %32 Canon Vixia HF R70 Lens Replacement: passo 20, imagem 3 %32
    • Grasp the plastic sides of the lens, and pull it away from the camera body to finish removing the lens.
Conclusão
Kristin Pitts
Membro desde: 02/28/17
201 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team S2-G2, Nance Spring 2017 Membro de USF Tampa, Team S2-G2, Nance Spring 2017
USFT-NANCE-S17S2G2
Membros da 4
Autoria de 14 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 3
Duração total: 594
