Introdução
This guide will help replace the internal battery and SD card reader, and opens up the central capturing unit to be disassembled
O que você precisa
Remove the strap by undoing the Velcro and pulling it through the thread points.
Remove the external battery pack by pressing down on the slide release and sliding it out.
Remove the two 3mm Phillips #000 screws.
Remove the 4mm Phillips #000 screw.
Quase terminado!
Conclusão
