Ir para o conteúdo principal
Canon Vixia HF R600 Casing Replacement
O que você precisa
  1. Canon Vixia HF R600 Casing Replacement, Handstrap: passo 1, imagem 1 %32 Canon Vixia HF R600 Casing Replacement, Handstrap: passo 1, imagem 2 %32
    • Pull up the Velcro strap starting from the front of the camera and working your way towards the back.
    • If you are adjusting the hand-strap, tighten or loosen the Velcro strap accordingly and reattach it.
    • To remove the hand-strap, pull the Velcro strip through the leather pad.
  2. Canon Vixia HF R600 Casing Replacement: passo 2, imagem 1 %32 Canon Vixia HF R600 Casing Replacement: passo 2, imagem 2 %32
    • Remove the strap from the camera body.
  3. Canon Vixia HF R600 Casing Replacement, Battery: passo 3, imagem 1 %32 Canon Vixia HF R600 Casing Replacement, Battery: passo 3, imagem 2 %32
    • Press in the battery release tab located on the bottom of the camera.
    • Slide the battery out from the body.
  4. Canon Vixia HF R600 Casing Replacement, Casing: passo 4, imagem 1 %32 Canon Vixia HF R600 Casing Replacement, Casing: passo 4, imagem 2 %32
    • Start by removing the two 6mm Phillips #00 screws located on the right side of the camera.
    • Remove four more 6mm Phillips #00 screws found on the bottom of the camera.
  5. Canon Vixia HF R600 Casing Replacement: passo 5, imagem 1 %32 Canon Vixia HF R600 Casing Replacement: passo 5, imagem 2 %32
    • Open the display screen and remove the three 5mm Phillips #00 screws.
    • Look to the swivel point for the screen to find the last two 5mm Phillips #00 screws that must be removed.
  6. Canon Vixia HF R600 Casing Replacement: passo 6, imagem 1 %32 Canon Vixia HF R600 Casing Replacement: passo 6, imagem 2 %32
    • Gently pull the plastic casing away from the camera.
Conclusão
Logan Coats
Membro desde: 02/10/16
522 Reputação
Autoria de 4 guias
Equipe
USF Tampa, Team 14-4, Lacy Spring 2016 Membro de USF Tampa, Team 14-4, Lacy Spring 2016
USFT-LACY-S16S14G4
Membros da 3
Autoria de 16 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 12
Duração total: 429
