Ir para o conteúdo principal
Canon Vixia HF R500 Zoom Control Replacement
O que você precisa
  1. Canon Vixia HF R500 Zoom Control  Replacement, Grip Belt: passo 1, imagem 1 %32 Canon Vixia HF R500 Zoom Control  Replacement, Grip Belt: passo 1, imagem 2 %32 Canon Vixia HF R500 Zoom Control  Replacement, Grip Belt: passo 1, imagem 3 %32
    • On the right side of the camcorder remove the grip belt.
  2. Canon Vixia HF R500 Zoom Control  Replacement, Battery: passo 2, imagem 1 %32
    • Hold on to the battery.
  3. Canon Vixia HF R500 Zoom Control  Replacement: passo 3, imagem 1 %32
    • On the bottom of the battery hold the battery release switch.
  4. Canon Vixia HF R500 Zoom Control  Replacement: passo 4, imagem 1 %32
    • Remove the battery slowly away from the camcorder.
    • Removing the battery quick or in a different angle may cause sparks and damage to device.
  5. Canon Vixia HF R500 Zoom Control  Replacement, Canon Vixia HF R500 Disassembly: passo 5, imagem 1 %32 Canon Vixia HF R500 Zoom Control  Replacement, Canon Vixia HF R500 Disassembly: passo 5, imagem 2 %32
    • Remove the two 8mm Philips #000 screws on the side where the grip belt was located on.
  6. Canon Vixia HF R500 Zoom Control  Replacement: passo 6, imagem 1 %32
    • Remove the two 4mm Philips #000 head screws from the bottom of the camcorder.
    • A hidden 4mm Philips #000 screw is shown under the black plug shown.
  7. Canon Vixia HF R500 Zoom Control  Replacement: passo 7, imagem 1 %32
    • Remove the side piece plate.
  8. Canon Vixia HF R500 Zoom Control  Replacement: passo 8, imagem 1 %32
    • Near the LCD screen, remove the three 7mm Philips #000 screws in the picture shown.
  9. Canon Vixia HF R500 Zoom Control  Replacement: passo 9, imagem 1 %32
    • Carefully place the camcorder where the inside of the device is facing upwards and remove the 3mm Philips #000 screw shown.
    • Do not use strong magnetic parts on the inside, as they may damage the device.
  10. Canon Vixia HF R500 Zoom Control  Replacement: passo 10, imagem 1 %32
    • Using the spudger, pull the tab shown to start removing the ribbon cable.
  11. Canon Vixia HF R500 Zoom Control  Replacement: passo 11, imagem 1 %32 Canon Vixia HF R500 Zoom Control  Replacement: passo 11, imagem 2 %32 Canon Vixia HF R500 Zoom Control  Replacement: passo 11, imagem 3 %32
    • Using the Spudger, carefully remove the two ribbon cables that are connected to the top of the device.
  12. Canon Vixia HF R500 Zoom Control  Replacement: passo 12, imagem 1 %32
    • Remove the top piece.
  13. Canon Vixia HF R500 Zoom Control  Replacement, Speaker: passo 13, imagem 1 %32 Canon Vixia HF R500 Zoom Control  Replacement, Speaker: passo 13, imagem 2 %32
    • Remove the three 6mm Philips #000 screws holding the black record piece.
  14. Canon Vixia HF R500 Zoom Control  Replacement: passo 14, imagem 1 %32
    • Remove the black record piece.
  15. Canon Vixia HF R500 Zoom Control  Replacement: passo 15, imagem 1 %32 Canon Vixia HF R500 Zoom Control  Replacement: passo 15, imagem 2 %32
    • Holding the full top piece remove the six 5mm Philips #000 screws holding the metal frame to the top piece.
  16. Canon Vixia HF R500 Zoom Control  Replacement: passo 16, imagem 1 %32
    • Carefully remove the the whole metal frame out of the device piece.
  17. Canon Vixia HF R500 Zoom Control  Replacement: passo 17, imagem 1 %32
    • Replace the defective speaker with a functioning one.
  18. Canon Vixia HF R500 Zoom Control  Replacement, Zoom Control: passo 18, imagem 1 %32 Canon Vixia HF R500 Zoom Control  Replacement, Zoom Control: passo 18, imagem 2 %32
    • Examine the grey zoom input tab located on copper plate.
    • Examine the black plastic zoom slider, on the top cover of the camera
    • Repair or replace damaged components and clear all debris from mechanisms.
Conclusão
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 12
Duração total: 264
