Introdução
If the lens cover on your camera will not open or close it could be caused by debris blocking the mechanism or a broken mechanism component. This guide will show you how to remove the lens cover from your camera so you can clean or repair it.
O que você precisa
Remove the two 8mm Philips #000 screws on the side where the grip belt was located on.
Quase terminado!
Conclusão
