Introdução
The charging port of the Canon Vixia HF R500 is connected by a fragile ribbon cord. This cord can become damaged or disconnected preventing the battery from charging. This guide will show you how to check the connection.
O que você precisa
Remove the two 8mm Philips #000 screws on the side where the grip belt was located on.
Ensure the ribbon cord is connected
Check the condition of the ribbon cord and replace damaged cord.
Quase terminado!
Conclusão
