Ir para o conteúdo principal
Canon Selphy CP720 Cooling Fan Replacement
O que você precisa
  1. Canon Selphy CP720 Cooling Fan Replacement, Cooling Fan: passo 1, imagem 1 %32 Canon Selphy CP720 Cooling Fan Replacement, Cooling Fan: passo 1, imagem 2 %32
    • Remove the four 8mm Phillips #1 screws from the bottom of the printer.
    Pergunte ao FixBot
  2. Canon Selphy CP720 Cooling Fan Replacement: passo 2, imagem 1 %32
    • Gently lift the top half of the printer off its base
    • A data ribbon attaches the two halves, so don't pull hard and keep the two halves close together.
    Pergunte ao FixBot
  3. Canon Selphy CP720 Cooling Fan Replacement: passo 3, imagem 1 %32 Canon Selphy CP720 Cooling Fan Replacement: passo 3, imagem 2 %32 Canon Selphy CP720 Cooling Fan Replacement: passo 3, imagem 3 %32
    • Remove the side panel by lifting it out.
    Pergunte ao FixBot
  4. Canon Selphy CP720 Cooling Fan Replacement: passo 4, imagem 1 %32 Canon Selphy CP720 Cooling Fan Replacement: passo 4, imagem 2 %32
    • Unplug the fan from the circuit board by gently pulling on the wire connector at the base of the port.
    • Do not tug on the wires. Slowly increasing force as you pull is the best way to detach the wires.
    Pergunte ao FixBot
  5. Canon Selphy CP720 Cooling Fan Replacement: passo 5, imagem 1 %32
    • Unscrew the two 8mm Phillips #1 screws from the fan.
    • Remove the fan from the panel.
    Pergunte ao FixBot
Conclusão
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 30
Ao todo: 576
