Ir para o conteúdo principal
Canon Selphy CP1200 Motherboard Replacement
O que você precisa
  1. Canon Selphy CP1200 Motherboard Replacement, LCD/Buttons: passo 1, imagem 1 %32
    • Unscrew the four 6mm PH000 corner screws.
    • This will require a screwdriver with a long, narrow shaft.
  2. Canon Selphy CP1200 Motherboard Replacement: passo 2, imagem 1 %32
    • Unscrew the three 4mm PH1 screws on the bottom of the printer.
  3. Canon Selphy CP1200 Motherboard Replacement: passo 3, imagem 1 %32
    • Gently pry open the top of the case from either the front or back.
    • A plastic opening tool may help.
    • Be careful in lifting the top assembly as it is attached to the motherboard at this point.
  4. Canon Selphy CP1200 Motherboard Replacement: passo 4, imagem 1 %32
    • Keeping the top assembly elevated, detach the ribbon cables connecting the LCD and buttons to the motherboard from the motherboard.
    • Tweezers may be useful given the limited space between the top assembly and motherboard.
    • The top assembly, containing both the LCD and buttons, will now be completely free
  5. Canon Selphy CP1200 Motherboard Replacement, Motherboard: passo 5, imagem 1 %32
    • Detach the fan cable from the motherboard.
  6. Canon Selphy CP1200 Motherboard Replacement: passo 6, imagem 1 %32
    • Detach the ribbon cable leading to the DC in port and battery leads.
    • Tweezers may be useful.
  7. Canon Selphy CP1200 Motherboard Replacement: passo 7, imagem 1 %32
    • Unscrew the three 3mm PH000 screws from the motherboard.
  8. Canon Selphy CP1200 Motherboard Replacement: passo 8, imagem 1 %32
    • Disconnect the bundled cables leading to the printing mechanism.
  9. Canon Selphy CP1200 Motherboard Replacement: passo 9, imagem 1 %32
    • Gently lift the motherboard and detach the ribbon cables leading to the print mechanism.
    • Tweezers may be useful due to the limited amount of space.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 12
Duração total: 1,078
