Ir para o conteúdo principal
Canon Selphy CP1200 LCD/Buttons Replacement
O que você precisa
  1. Canon Selphy CP1200 LCD/Buttons Replacement, LCD/Buttons: passo 1, imagem 1 %32
    • Unscrew the four 6mm PH000 corner screws.
    • This will require a screwdriver with a long, narrow shaft.
  2. Canon Selphy CP1200 LCD/Buttons Replacement: passo 2, imagem 1 %32
    • Unscrew the three 4mm PH1 screws on the bottom of the printer.
  3. Canon Selphy CP1200 LCD/Buttons Replacement: passo 3, imagem 1 %32
    • Gently pry open the top of the case from either the front or back.
    • A plastic opening tool may help.
    • Be careful in lifting the top assembly as it is attached to the motherboard at this point.
  4. Canon Selphy CP1200 LCD/Buttons Replacement: passo 4, imagem 1 %32
    • Keeping the top assembly elevated, detach the ribbon cables connecting the LCD and buttons to the motherboard from the motherboard.
    • Tweezers may be useful given the limited space between the top assembly and motherboard.
    • The top assembly, containing both the LCD and buttons, will now be completely free
Conclusão
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 4
Duração total: 394
