Ir para o conteúdo principal
Canon SX40 HS camera LCD Screen Cover Replacement
O que você precisa
  1. Canon SX40 HS camera LCD Screen Cover Replacement, LCD Screen Cover: passo 1, imagem 1 %32 Canon SX40 HS camera LCD Screen Cover Replacement, LCD Screen Cover: passo 1, imagem 2 %32
    • Open/turn the LCD screen until it fully extends outwards.
    • Remove these two 4 mm black screws on the left side of the screen with a Phillips size #00 screwdriver.
  2. Canon SX40 HS camera LCD Screen Cover Replacement: passo 2, imagem 1 %32
    • Partially close the screen and rotate it 90 degrees until the screen is facing upwards (photo view from the left front of the camera). Remove the 4mm black screw, indicated in the picture, with a Phillips #00 screwdriver.
  3. Canon SX40 HS camera LCD Screen Cover Replacement: passo 3, imagem 1 %32
    • Rotate the screen 180 degrees until the monitor is facing downwards. Remove the 4mm black screw, indicated in the picture, with a Phillips #00 screwdriver.
  4. Canon SX40 HS camera LCD Screen Cover Replacement: passo 4, imagem 1 %32 Canon SX40 HS camera LCD Screen Cover Replacement: passo 4, imagem 2 %32 Canon SX40 HS camera LCD Screen Cover Replacement: passo 4, imagem 3 %32
    • Using a plastic opening tool, remove the unfastened LCD screen cover from the camera.
    • Be careful not to pry and damage the circuit card under the screen cover.
  5. Canon SX40 HS camera LCD Screen Cover Replacement: passo 5, imagem 1 %32 Canon SX40 HS camera LCD Screen Cover Replacement: passo 5, imagem 2 %32 Canon SX40 HS camera LCD Screen Cover Replacement: passo 5, imagem 3 %32
    • This is what you should see after removing the LCD screen cover. Replace the LCD screen cover if damaged.
Conclusão
John Bui
Membro desde: 03/26/15
352 Reputação
Autoria de 3 guias
Equipe
UMass Dartmouth, Team 7-7, Cichon Spring 2015 Membro de UMass Dartmouth, Team 7-7, Cichon Spring 2015
UMASSD-CICHON-S15S7G7
Membros da 3
Autoria de 3 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 17
Duração total: 1,741
