Ir para o conteúdo principal
Canon SX40 HS camera Flash Cover Replacement
O que você precisa
  1. Canon SX40 HS camera Flash Cover Replacement, Flash Cover: passo 1, imagem 1 %32 Canon SX40 HS camera Flash Cover Replacement, Flash Cover: passo 1, imagem 2 %32
    • Extend the flash cover upwards and remove the 4 mm black screw located on the left side. You will need a Phillips #00 screwdriver to remove it.
    • Repeat to remove the 4 mm black screw located on the right side.
  2. Canon SX40 HS camera Flash Cover Replacement: passo 2, imagem 1 %32
    • Remove the plastic cover using the iFixIt Plastic Opening Tool.
    • The plastic cover can only be removed in the down position.
  3. Canon SX40 HS camera Flash Cover Replacement: passo 3, imagem 1 %32 Canon SX40 HS camera Flash Cover Replacement: passo 3, imagem 2 %32
    • After removing the flash cover, remove the 6 mm silver screw on the right side with a Phillips #00 screwdriver.
    • Repeat to remove the 6 mm silver screw on the left side with a Phillips #00 screwdriver.
  4. Canon SX40 HS camera Flash Cover Replacement: passo 4, imagem 1 %32
    • Replace the external flash cover or the internal flashlight when all 6 mm silver screws are out.
Conclusão
To reassemble your device, follow Steps 1-4 in reverse order.
Uma outra pessoa concluiu este guia.
John Bui
Membro desde: 03/26/15
352 Reputação
Autoria de 3 guias
Equipe
UMass Dartmouth, Team 7-7, Cichon Spring 2015 Membro de UMass Dartmouth, Team 7-7, Cichon Spring 2015
UMASSD-CICHON-S15S7G7
Membros da 3
Autoria de 3 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 11
Duração total: 801
