Introdução
The Canon SX40HS is a high-powered, user-friendly digital camera. The SX40 HS is a great entry-level camera that provides simplicity and quality at a low cost. Due to wear and tear, it is important to know how to change the flash cover. This guide is geared towards everyday photographers and professionals.
O que você precisa
Extend the flash cover upwards and remove the 4 mm black screw located on the left side. You will need a Phillips #00 screwdriver to remove it.
Repeat to remove the 4 mm black screw located on the right side.
To reassemble your device, follow Steps 1-4 in reverse order.
Uma outra pessoa concluiu este guia.
