Ir para o conteúdo principal
Canon Powershot SX500 IS Control Dial Replacement
O que você precisa
  1. Canon Powershot SX500 IS Control Dial Replacement, Battery: passo 1, imagem 1 %32
    • Rotate the camera to expose the underside of the camera.
  2. Canon Powershot SX500 IS Control Dial Replacement: passo 2, imagem 1 %32
    • Slide the rounded rectangle tab to the left to release the battery cover.
  3. Canon Powershot SX500 IS Control Dial Replacement: passo 3, imagem 1 %32
    • Push the small orange tab forward to release the battery (Battery is ready for removal).
  4. Canon Powershot SX500 IS Control Dial Replacement, Back Cover: passo 4, imagem 1 %32 Canon Powershot SX500 IS Control Dial Replacement, Back Cover: passo 4, imagem 2 %32 Canon Powershot SX500 IS Control Dial Replacement, Back Cover: passo 4, imagem 3 %32
    • Using the Phillips 00 screwdriver, remove the two 4mm top screws above the LCD screen.
  5. Canon Powershot SX500 IS Control Dial Replacement: passo 5, imagem 1 %32
    • Using the Phillips 00 screwdriver, remove the two 4mm side screws to the left of the LCD screen.
  6. Canon Powershot SX500 IS Control Dial Replacement: passo 6, imagem 1 %32
  7. Canon Powershot SX500 IS Control Dial Replacement: passo 7, imagem 1 %32
    • Using the Phillips 00 screwdriver, remove the three 4mm screws from the underside of the camera.
  8. Canon Powershot SX500 IS Control Dial Replacement: passo 8, imagem 1 %32 Canon Powershot SX500 IS Control Dial Replacement: passo 8, imagem 2 %32
    • Using the plastic pry tool, remove the back cover from camera.
  9. Canon Powershot SX500 IS Control Dial Replacement, Control Dial: passo 9, imagem 1 %32
    • Using the Phillips 00 screwdriver, remove the two 3mm screws closest to the right of the LCD screen.
  10. Canon Powershot SX500 IS Control Dial Replacement: passo 10, imagem 1 %32
    • Using the Phiillips 00 screwdriver, remove the 4mm screw to the right of the control dial.
  11. Canon Powershot SX500 IS Control Dial Replacement: passo 11, imagem 1 %32
    • Using the spudger, lift the control dial to the right of the LCD screen.
  12. Canon Powershot SX500 IS Control Dial Replacement: passo 12, imagem 1 %32
    • Using the spudger, lift the connection tab and remove the control dial's orange ribbon from motherboard.
Conclusão
Uma outra pessoa concluiu este guia.
Um comentário
Gracias gracias gracias
edgarlugo20111917 - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 11
Duração total: 470
