Ir para o conteúdo principal
Canon Powershot SX30 IS LCD Panel Rear Cover Replacement
O que você precisa
  1. Canon Powershot SX30 IS LCD Panel Rear Cover Replacement, LCD Panel Rear Cover: passo 1, imagem 1 %32
    • Turn the camera so the back of it is facing you.
    • Pull the LCD screen towards you in order to open it,
  2. Canon Powershot SX30 IS LCD Panel Rear Cover Replacement: passo 2, imagem 1 %32 Canon Powershot SX30 IS LCD Panel Rear Cover Replacement: passo 2, imagem 2 %32
    • Unscrew the two 3 mm screws shown on the left side of the LCD screen panel using a Phillips screwdriver.
  3. Canon Powershot SX30 IS LCD Panel Rear Cover Replacement: passo 3, imagem 1 %32 Canon Powershot SX30 IS LCD Panel Rear Cover Replacement: passo 3, imagem 2 %32 Canon Powershot SX30 IS LCD Panel Rear Cover Replacement: passo 3, imagem 3 %32
    • Unscrew the two 3 mm screws shown on the right side of the LCD screen panel.
  4. Canon Powershot SX30 IS LCD Panel Rear Cover Replacement: passo 4, imagem 1 %32 Canon Powershot SX30 IS LCD Panel Rear Cover Replacement: passo 4, imagem 2 %32
    • Using the plastic opening tool, remove the rear case of the front LCD cover.
  5. Canon Powershot SX30 IS LCD Panel Rear Cover Replacement: passo 5, imagem 1 %32
    • Pull off the back panel of the LCD screen and the plastic wire protector. Then replace the back panel.
Conclusão
Ellis DeVoe
Membro desde: 04/14/15
580 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team 5-12, Maness Spring 2015 Membro de Cal Poly, Team 5-12, Maness Spring 2015
CPSU-MANESS-S15S5G12
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 6
Duração total: 306
